Electrical-Signal lights dont work, but 4-ways do?? Any advice
Oct 16, 2008
Hey i just got my self a 180sx, everything is pulling strong with the car besides the fact that the signal lights dont work. They dont show up on the dash or on the exterior of the car (so i know its not the bulbs/fuse), other then that i have no idea. You think it would be a quck and easy fix, or long and difficult, any avdice can help.
Thanks for your help.
kaminari
1,031
43
Taiping
Wht do u mean 4-ways do?
Put the hazard signal..if blink then ur signal lever myb got a problem.Broken plate inside or misplace.Common for old Nissan car.
if hazard not blink then there is wiring disconnected or cut.
180sx-Owner
Yea, when i turn the 4 way flashers on they flash inside and outside the car, but when i try and put a signal on by itself nothing happens...
kaminari
1,031
43
Taiping
Since it`s troublesome to open the steering column...u might do pre-test 1st such as grounding problem,fuse and power relay.If fine then u can proceed to Signal flasher unit behind the steering column.Last go for the lever.
cheers
when the car station it is cold...when driving fast like 140 km/h..the aircond not cold anymore...got some stink smell like u just switch on ur air cond
what is the problem?and why sometimes got the click click sound when the air cond is on..
