EF Customs - Absorber and Springs Servicing & Mods
EFN
1,294
19
Batu Caves
Dear All,
My latest offering are as follows:
- Coilover springs installation and modification into non Coilover dampers - RM50 each dampers
- Dampers servicing (replacement of Hydraulic Oil and seals) - RM50 each dampers
Coilover Springs available:
TITAN 2, 3, 4, 5, 5.5 and 6Kgs - RM80 each NEW!
Hydraulic Oil used:
- Castrol High Pressure RM10 for two dampers
- Motul Sports/Competition RM30 for two dampers
Options:
You can send your car to me and it will take half day to complete. This way removal and installation will be charged at RM10 for 1 absorber. Or it will be better if you just simply send me your absorbers and of course no charge will be inccured.
Applicable to:
Any absorber/dampers that uses bolt type screw at the body to hold the shaft like Corolla/Levin/Trueno AE111 and AE101 Japanese dampers.
Note:
If you go for Coilover Spring mod, it will not be height adjustable - just that I will modify the "plate" holding the springs to accomodate small diameter coilover springs. And height will be set at preffered length during the modification itself. Advance appointment is required before you send in the dampers.
Important NOTE!:
Applicable to all Oil and Oil+Gas dampers only. Gas dampers cannot. For Oil+gas dampers it will be 100% Oil damper after servicing - and I can confirm that the result will be quite satisfactory even with Oil only (I am using a set now)
For more info just call me at 012-240 7780
conflict_tuning
138
Ampang
www.mitzmara.com
bro..
i want my car to be rally look..can aaa??kasi tinggi sket front n rear..than i wan change the spring for all the absorber...front abs is ae92..rear is kyb sr...can aaa??how much??mana bikin itu abs...at ah pau shop kaa...ke suriani???:cyclops:
EFN
1,294
19
Batu Caves
conflict_tuning said:
bro..
Sure! rally look can! but I have to see first if your dampers can be modded. It will be done not far from Apau's.
hitz
1,111
5
5,138
Kepong, KL
Yes.. .. Finally new EF Custom Mod is out!! Gonna call you soon.... Wanna change my front damper oil.. .. ..
n0th1n
1,161
12
japan
junk-dealer.blogspot.com
saya punya absorber yang leak itu hari buleh serbis kah? kasik kaw2 punya hard buleh?
EFN
1,294
19
Batu Caves
Can brader, last time dunno how to do. Now can adi hahahaha
hitz
1,111
5
5,138
Kepong, KL
Bro wah business very good oredi.. .. Forgotten to call me back also.. :p
sbirdz
1,851
29
S.Kembangan
sbirdz_jackals.blogs.friendster.com
Brother EFN,
still not sure what you are talking above.. ^_^ sorry r.. but the price is nice and my car is sort of soft during corners... see if I see you next time on gathering hopefully u will explain to me in more detail le.. ^_^
EFN
1,294
19
Batu Caves
Aloo frens, sorry for late reply. Was busy yesterday at office.
Anyway, Superstrut is also servicable if the shaft can be removed from the casing.
guys,
currently having trouble with the throttle body of the 1.3 satria. my fren suggested that the throttle body kong already.......... he was suggesting that i should give it a try by fixing those throttle bodies from 1.5 or 1.6 engine as it gives more power...........
any suggestions? appreciate it........
