Edfc error EE help
sigariga
22
Hi friends,
Need help here.. hv juz installed Edfc on my flexs but 'EE' error showed up. EE for Front n 16 for rear. Even when unplugged front & rear connectors its still appeared the same. done reset oso same. is it due to controller fault or power wiring?
Appreciate ur inputs
egb18c
922
94
kuantan
my best assumption is that the wiring or connector is loose.
since sometimes my controller will display EE also,so what i did is to turn the car off and on again,then its gone.
just check your wiring first.
sigariga
22
Egb18c,
Ok, will check the powerwires (constant & accessory) tomorrow.. do you know if there got any specific voltage/amp requirement for the controller?
sigariga
22
case resolved.. it's controller problem. wiring checked all ok.. went to halfcut shop, swap with other controller and no more error shown.. poket kopak.. thanks anyway.
sigariga
22
600 brand new at chopshop selayang utama
its exactly what i want!
before my first retune, the ride was extremely harsh! now after everything has settled, asked richard to make it a LIL softer and lower the back by 10mm.. ALL is well :lol:
driving around mpd, I could hardly feel all the lil bumps and stuff, yellow lines, as hard as i tried, i could barely feel them.
lets visit this again a month from now
