Dear all MR2 bros & Sis,
I would like to share my experience wrt to main ECU, power steering and air conditioning controls ECU that have plaqued many MR2 owners for a long time. I have been thru like many owners with burnt main ECU , intermittent functioning power steering and clicking air-cons comp. for some years to finally found the culprit after went thru 3 burnt ECU ( managed to save 2 ECU ).
In fact most of the MR2s have been 20+ years old and the electronics parts have also aged especially those little e-caps. Thats the culprit that caused burnt ECU and crazy frustrating power steering intermittently. This e-caps have a designed shelf life of 8 years and most MR2 cars have at least 20 years in service and those e-caps leaks internally that causes short in the circuit that caused the ECU PCB track to burnt. I personally have stranded on the road because of these damn e-caps. Anyway they are supposed to be changed out periodically says every 5 years , for sake of drivability. I managed to replaced 2 out of 3 main ECU units and back to full service except one ECU PCB track was too badly burnt beyond repair ( e-caps leaks internally and caused direct short intermittently initially and will finally short out fully ). Same goes to power steering and air-cons ECU. There wasn't many e-caps in them 5 - 10 the most and they are cheap, cost from a few ringgits to about 15 ringgits the most. The work to replace them needs a bit of simple soldering skill. I would suggest to remove the ECU boxes and get the electrical repair shop to change them out for you if you can't do it yourself. It would cost less than 100 ringgit each.
DON"T WASTE TIME switching your key trying to get your power steering to work, I have been thru that. It is causing more wear and tear on your ignition switch. It is not the contacts oxidation, believe me you can strip it and you will find the contacts are perfectly clean and by that time you have ruin it.
If your are adventurous you can replace the relay to contactless solid state switch module if you are worried of contact fouling.
Well you can alternatively buy a second hand ECU from the chop shop but again it may last for a few years (if you are lucky) and they cause you probably 500 to 600+ ringgit for each box.The best and assured way is to remove your original ECU and get someone to replace those damn e-caps and you will be sure and sound for next 5 to 10 years without any trouble.Furthermore MR2 is getting less and less and the chop shop parts are getting less and probably hard to find and the price they ask will be lot higher.
BTW my main ECU is a self repaired unit and I have been using it for a couple of years now, no problem. I replaced those nasty e-caps and repair the burnt PCB tracks and they are as good as new. Remember to change out those e-caps regularly every 5 to 10 years and you will be loving your 2s forever.
Another thing to share is, the alternator. Instead of buying chop shop used unit which is aged and unreliable, why not replace with new one.Also went thru a few chop shop units that last a short time with bad regulators and burnt diodes. Toyota Land Cruiser II used the same unit. It is a direct drop in and they are 100+ amps too. You can buy them new from the spare part shop. Please remember all parts are designed for 15 years max. so better get new one if you can rather than having headache with used one.
Hope my bad experiences will help others...........this applies to other old cars too.
Enjoy your 2s............happy driving.
