hi i'm not sure if this has been asked b4 or not. which is better ? two of 2 channel amp vs one of 4 channel amp. from the same brand same fuse rating.
as far as i know, in order to protect a bigger power a bigger fuse is used.
but according to specs, one amp is 4x60rms while the other is 2x60rms using the same fuse. how ?
juz in case ur wondering.. i need a total of 4 channels, 2 to power 6" woofer, 2 to power midrange + tweeter.
the total of 2 2channel amp is only a bit higher than 1 4channel amp. which shd i get ?
