- Nov 30, 2006
- 51
- 0
- 1,506
yea, so do the engine balancing maybe. very expensive but not gain huge power lor. tq for ur company info. i like it. now im very busy... maybe soon :) :)
Bang on target.for ur guy info,70% of ur underhood temperature come's from ur extractor or manifold.to wrap or not,it's up to u guy's.1 more thing is,if u guy use extractor,only wrap extractor made out of stainless steel like the japanese made 1.don't wrap on ur hot bit extractor or it will crack under extreme heat.wrapping extractor is good from my point of view as it lower the under hood temp so ur car will work more efficiently.digest more oxygen n increase the exhaust/manifold efficiency by creating
a better scavenging effect.
some of those exhaust wrap is mix with fibreglass.that's y the itch.y itchy feel man !!
no lar bro.those wrapper can hardly burn.The type of exhaust wraps make a difference too. Don't get those cheap cheap ones. The heat will make it hardened and brittle in no time.
I just wrapped mine for a week and the whole thing become so brittle that it breaks on contact (trying to take out the extractor), it also got burnt marks... Possible fire hazard?
Just my two cents.
What you use to tie the Aluminium foil down?Use Aluminium foils.
Crunch it up and wrap it up. Use thick wire to hold it in place.
I found that my acceleration is faster at high speed 100kmh++ after put the wrap.
Before that, after fast edi, acceleration is slow and need to rev quite high to get desired power. now is more smooth.
Here is how mine looks like:
Alternatively, if u got money its better u buy the real thermal wrap. cost RM80 not include instal at ENEOS.
OK thanks for the explanantion.jebatdex,
if you wanna warp thermacloth then it is good. Try your best to ensure the thickness of the wrap is consistent at the length of the extractor. If the wrap is thick here, thin there on the extractor, then there is a chance that the extractor would develop crack, since expansion(due to uneven heat distribution) is different on different part of the extractor.
Just like a glass would crack when boiling water is poured into it.
