hello.. just wanna know, isit a problem if the engine block sound like 'ktik-ktik' (as it was very hot) after a long jurney?? fyi, i drove astina bpt with std i/c and no air scoop or what so ever..
:X-:
yup,it was quite unsafe when the engine is running lean...it can cause piston crack...
try to use such like SAFC,Emanage...and etc act as piggybag...
cheers...
happy solving your problem...
im juz curius
fitting in a 1.5 hydraulic clutch pump in a 1.6liter engine does it effect anything ?
its look almost the the same like the 1.6 hydraulic pump but smaller a bit ..
thanks !
