hope this helps...
corolla 6th generation 1987 (malaysia market)
AE92 (for 1.6) known as 1.6GL. engine 4A-F 1.6 16V twincam. facelifted in 1989 known as 1.6 SELimited. new grille, rear combi lamps use clear lens instead of orange.
EE90 (for 1.3) known as 1.3GL. engine 2E 1.3 12V. facelifted in 1989 known as 1.3SE. similar design to 1.6 spec.
7th generation corolla 1991 (malaysia market)
AE101 (for 1.6) known as 1.6 SE-G. engine 4A-FE 1.6 twincam 16V. facelifted in 1994, also with new grilles and new rea combi lamps. clear lens signal. new wheel cover also.
EE100 (for 1.3) known as 1.3GL. engine 2E 12V. facelifted in 1994, with similar changes with 1.6. known as 1.3SE but with power steering.
8th generation 1995 (malaysia market)
AE111 (for 1.6) known as 1.6SE-G. engine 4A-FE 16V twincam. also available as 1.6 auto and auto with ABS. facelifted in 1998, complete makeover with new diamond type headlamps, rear combi lamps with new quarter panel. new dashboard comes with twin airbag. wired type alloy wheels optional. also available as very limited model with complete body skirting.
EE111 (for 1.3) known as 1.3GL. this time engine has EFI, if not mistaken 4E-FE with 16V twincam. also available as a 3 speed self shifter. facelifted in 1998 with similar spec to 1.6.
9th generation 2002 (for malaysia market)
this time local franchise holder had overhauled corolla to meet new market requirements. known as Altis, its only meant for ASEAN market and not even available in Japan as it wud be too big to be called Corolla. no more 1.3. this time toyota went upmarket with 1.6 and 1.8 engines with 16V twincam, VVTI and timing chain instead of cambelt. engine series is 1ZZ-FE and 3ZZ-FE. model code known as ZZE121 and ZZE122. facelifted in 2004 with LED type taillamp and 16" alloys for top spec 1.8G.
all electronic gizmos come as standard. ABS, EBD, traction control.
