Didint ground piggyback/ecu will cause rough idling?
Originally Posted by risyia
did not ground the ECU/Piggyback properly during the installation - causing the idling to be rough - now that it is grounded, the idling is much smoother but still not as smooth as an NA engine.
Calling all sifus, out of curiosity, so far I have not heard grounding a piggyback can give better idling, flip thru instruction booklet from e-manage also cant find any instruction about grounding it.
And if it is true, which part of the piggyback body did you connect the wire? As most piggyback body are made of plastic. Share with us your experience ok? Cheers :D
