DD RACING 4 POT BRAKE CALIPER KIT
*SAFETY START WITH DD*
Heavy duty stainless steel pistons reduce heat
transfer.
PACKAGE CONTAIN : CALIPER 4 POT x 2PCS
DISC ROTOR 303MM x 2PCS
ADAPTER x2 PCS
BRAKE PADS 1SET "550DEG"
MATERIAL : FORGED aluminum alloy
YOU ARE BIDDING ON A COMPLETE FRONT BRAKE KIT FROM
DD///.
EACH KIT CONTAINS A MATCHED SET OF CALIPERS AND
ROTORS SPECIFICALLY DESIGNED FOR EACH APPLICATION.
INSTALLING LARGER BRAKES WILL DECREASE YOUR
STOPPING DISTANCE, PROLONG THE LIFE OF THE PADS
AND ROTORS AND FILL UP THE SPACE BETWEEN THE
CALIPER/ROTOR AND BARREL OF WHEEL
D&D PERFORMANCE
email:[email protected]
hp: 60163328136 seng
transfer.
ADAPTER x2 PCS
DD///.
D&D PERFORMANCE
