d16y prob..
sazleej
85
guys.. what is wrong with my engine?? i have to change the plug every 3 month.. using ngk platinum.. before this, i only change it annually.. haihhhh!!! really gimme the headache.. cant afford to change the engine nowdays.. tight budget.. the mech before adjust the engine with turn a bit the distributor.. is there a solution??:banghead:
AD_EG
6,000 RPM
6,328
231
Ipoh
why must change every 3 months ... is it dead?
when the plugs are removed is it whitish ? or blackish?
pc_teh
93
1,508
Do top overhaul to remove the carbon on the piston should solve the problem ....
sazleej
85
top?? is there a set for it? or i have to buy one by one?? a set i mean is all the gasket together.. cannot seem to find here.. only see at ebay.. ehehehehhee
Hi bro,any1 noe how to open up the 1st gen P.saga (Taxi type) aircond control switch panel to replace all the bulb in it?my control panel currently.....all black..at the nite cant see anything...need help...thanks
