CT-26 to TD05H16G
celica688
12
i own a celica with a 3sGTE engine from ST185.. recently i changed the turbo from the original CT-26 to TD05H16G and it happen to be full boost.. i cheaked the wastegate host no leaking or sumthing.. I need help here to make it back to 1 bar boost.. anyone can help me plss...
yip_cheng
36
mind to ask,wat is the max boost for ct26?above 1 bar?just curious..lolz.
jinkl
4,624
376
3,183
use a boost controller ?
td05 actuator opens at 0.6bar
and td05 are known for turbine housing cracks, do check
Hi guys, changing the throttle body can cause any problem to the engin or not?
Do i need to retune my ecu?
Now i'm using perdana throttle body on 1.5 intake manifold. Didnt feel much different, maybe already used to it. Going to change it back to 1.5 throttle body to feel the difference.
Is changing the intake manifold give any difference to the engin reponse. cause i still have a ECI Multi intake manifold with 1.6 throttle body lying around in my house from my previous 4g13 engin...
