Hi bros can anyone tell me what will fit? Would an evo 4 manifold, turbo and dp bolt it? What models can/cant
so a evo 4 turbo, manifold and downpipe will just bolt up? oil and water lines still match up? or will i need the ones from the evo 4 turbo?evo 4 to 9 is compatible wif treks
No go? what seem to be the problem with your T3 setup Chubster?so a evo 4 turbo, manifold and downpipe will just bolt up? oil and water lines still match up? or will i need the ones from the evo 4 turbo?
i have a really nice t3 manifold, turbo and downpipe sitting in the garage, i did test fit last night and its a no go, bit bummed really but a guy in my hometown has a evo 4 setup going cheap.
thanks avant. yea no go, cant be bothered with the hassel. the t3 turbo sits quite low so a custom intake pipe will be needed, 1 stud hole on the manifold is about 1mm off, so would require some machining, 3" downpipe is just a tad to large and hits the starter motor bracket. because of that the pipe wont sit up high enough. so that would require a custom job there aswell. and im not sure but it looks like the flange is offset by about 30deg to the tubo so the bolts dont line up.No go? what seem to be the problem with your T3 setup Chubster?
I would try to make it work since U've already got all the major hardware, unless it's a serious compatible or mounting issue. Let me know, see if I can help :)
---------- Post added at 10:22 AM ---------- 6 hour anti-bump limit - Previous post was at 10:17 AM ----------
If not mistaken, the original oil & water lines can be used, but the fittings on TD05 turbo are bigger. Your best bet is to get the Evo 4 turbo with all the fluid lines & fittings attached.
suposidly made for a evo 7,8,9. the auto box dosent help, its right there in front of the turbo outlet.is ur t3 maniold custom made?
No worries chubster. Just a small hiccup =)thanks avant. yea no go, cant be bothered with the hassel. the t3 turbo sits quite low so a custom intake pipe will be needed, 1 stud hole on the manifold is about 1mm off, so would require some machining, 3" downpipe is just a tad to large and hits the starter motor bracket. because of that the pipe wont sit up high enough. so that would require a custom job there aswell. and im not sure but it looks like the flange is offset by about 30deg to the tubo so the bolts dont line up.
ill be able to sell it for what i got it for so not a major there. i had suspiscions so thats why i did a test fit this weekend. im glad i did really
Hi carnetics,Hi sorry had to ask. So if I go out and buy a TD05 turbo from a Evo7-9, all the lines and fittings etc, buy a td05 manifold for a evo 7-9 and also get a turbo downpipe, they will all just bolt straight onto my air trek? No need to remachine any of the holes etc? And then tune of course.
Other than these parts, do i also need to change the injector resistors? I vaguely remember somewhere someone said airtreks are high impedance and need to change to low impedence.
So what are the ECU settings for the pinks (latency / scaling)?My ATR was mod to TD05 setup by previous owner..
from what i know, my ATR are using WRX STI pink injectors..direct fit..
