coil nissan A33
dev7907
Feb 19, 2012
10
Johor bahru
What are symptoms if one of coil is spoilt?
I heard nissan A33 got 6 coils.
There is cut off in engine sound sometimes and when checked with mechanic, i was told that its due to coil.
Pls advise sifus...
12savefuel
195
75
Yes, engine can die with a faulty coil or erratic idle. Open up all the s.plugs and look at the sprak plug. The one with the spoilt coil should be black or much much blacker compared to the others. Another test is to idle the engine as slowly disconnect and connect each coil connector. The faulty coil will have little to no effect on engine idle. The good coil disconnected will cause the engine to idle rough and smoothen back when connected.
The Marketplace Top Posts
Was the above your teenage dream car? it was almost impossible to own one then, not to mention now. However, there's a one up for sale, now. It's a Yellow 2-door, yes, but nothing firm on it's originality. It could well be your dream come true...
