jinkl said:
take the sample bearing to sparepart shop
they can order it from NTN ot NSK
Hey Jin,
I need a suggestion. The Twin Plate was bought from SS Racing. Those donkeys gave the smaller bearing - which is the EVO 3 original Bearings. Now I need to find the original bearing. Any idea where I can get it.
Another thing I realised is that the Flywheel plate got makan a little. I suppose due to pressure. You know the black colour plate just where the bearing sits.
I need a suggestion. HKS plates can be dismantled and the plate can be taken out. Can I sent it for engineering may be welding shop n ask them to add metal to it ? The plate is not gone but worn a little. Too much pressure can break it.
As for the bearing - I do not have sample. So I am not able to seek for NTN bearings. Any idea on how it can be solved.
FYI - My car is out. Feels much lighter. The throttle response is now better - As I have reduced weight at the balance shaft, 4 wd gear and engine balancing. I am running at low boost waiting for the engine to run in. Later will test but the clutch is std. I doubt can test with that - just too much of slipping.
Thanks in advance for all your opinions.
Cheers.
