cant open my fuel cap liao
lan evo
3,063
129
5,163
is the cable broken?if yes u can try to find it at chop shop.if cant get it then u can customise one
kampoon
1,205
89
1,648
go modify Mr Bean punya lock lor........hehe
mobilo
57
Klang Valley
Mynndawg,
Are you talking about the "lever" to pop open the fuel tank cover? If so, have someone pull the lever and you go check whether the small arm moves or not on the inside of the cover itself. If it's not moving, then perhaps cable got disconnected somewhere.
I don't think it's something serious but if the cable alrdy snapped, then it's quite tricky to have it replaced. Not sure where the cable is lined up on your car but try to trace it.
Good luck
leslie
2,946
230
5,163
its not a hard thing to fix... dont worry man... !!! mine sometimes doesn't pop up as well... i usually insert something underneath the lever to keep it up so i can walk to the tank cover and open it manually... but it only happens to me sometimes...
acbc
4,615
8
KD
I believe there is a spring on the cap itself. Sometimes, u just need to bent it a little just like what I did for my car. Or spend RM 10 for a used cap from the chop shop. Evo maybe a little expensive.
Jabby
21
bro i had da same prob too last time on my e7... bought da ori mitsu spring for 30 bucks i think... now ok d...
Jabby
21
i went to a sparepart shop in ss19 sj... they ordered from mitsu supplier... took a day to get it...
