scomatic said:If want to bolt the turbo, I much recomend for AE92 with non-TVIS
Step to bolt in also simple... Just change the piston to supercharge piston, then can go for Turbo liao...
rollakid said:but if lucas ask if there's a way to bolt on turbo to 20v, and he already have a 20v. if you ask him to use other engine won't it be easier to just get the 4agze and throw away the supercharger and bolt on a turbo? ecu still can use ler...
sylkhannaz said:Here's a pic of a turbocharged 4AGE. Raymond's. 1.0bar
But, 20V would be a lot harder. It would cost around 7-8K and i dont think the boost can go up to 1bar. 06++ maybe. Raymond offered to turbocharge my bt but i guess i'm too slow of a driver, like snail one.
U will lose VVT as it draws out raw power but possible if u slap in Microtech. The owner of that car (in image) done a number of turbocharged 4AGE, svt, bt. Should you need to know more, i can give you his phone number.
Similar threads | |
