dats confirm a pivot speedmeter X...i use to own it.its a direct tap into ecu...
i think the pivot meter is more trusty then his panel meter....if according to the speedmeter..nothing wrong with the video...if according to his panel....theres something definitely wrong...
the meter he using 0-180kmh .... then he put the white meter cluster 0-240kmh .... the white meter cluster is design for 0-240kmh meter (such as gti , putra) ... of coz the speed will high at the meter ... actual as slow..
Just finished the transplant of K3-VETR from a YRV Turbo R into my Myvi 1.5 , also just finished all the supporting mods like FMIC,Fuel Pump,Sard Fuel Regulator,TurboSmart Boost Controller,full turbo back 2" exhaust & Emanage Blue/M7 Em-Con ... Turbo&all other stuff are still stock .
Ready for Dyno tune ...
What figure should i expect of a stock YRV Turbo & with all the supporting mod i've done ?
Target boost is around 0.9-1Bar Kg/Cm
Thanks for any advice =)
