can a waja chassis withstand a 4G63?
SHENzz
45
errr...can even a waja chassis withstand a 4G63 under his hood...cos from wat i think is its chassis is not made to withstand such a powerful engine...so is it ok to transplant a 4G63 engine to it will it break up its chassis...and also its suspension will it be able to withstand such a heavy engine compare to its 4G18 which is very light....:regular_smile:
bnr34
403
6
yes no problem......
waja chasis is very strong. it is different with wira, satria, but putra n gti i dono lar....
from my experiance.... i own a wira with a VR-4 last time... after using the vr-4 engine for about a year.. i can feel that the chasis is seems like wanted to kayak alreadi... because the body cannot tahan we mofidied to FF and pull the body too hard... that y u can feel like the whole car is very longgar....longgar....
n now my waja is using an evo engine... this problem never occur... and i can feel the body is still so strong.....maybe u can change ur engine mounting to rally art mounting or els... yes the engine is slightly heavy than 4g18p, that y u may change the absober to other adjustable...
it is very easy the different within waja n wira chasis... u try to hv a ride on this 2 different car, than try to pass through some hole, or not smooth road, than u will hear some different sound..
this is wat my experiance.....
for me oppinion....
our nation car..., perdana is the strongest body,, 2nd with waja...
or u guys got any other different oppinion, just correct me..... cheers....
SHENzz
45
bnr34 thnkz for the opinion as u mention change to other coilover...the other coilover is using the waja spec or having more kg/mm in front as the engine is heavier or can i jus use the waja spec coilover to withstand the engine...and also by adding those bars to the car does it strengthen the car chassis or jus improve the handling only...and also i tot wira is a FF car how come u still need to modified it to FF??
bnr34
403
6
so u own a waja right??? n going to transplant to evo engine?
ok.... how about u come to join our tt lar... maybe i can tell u more--as wat i know lar.. cos here is something difficult to type out wat to change, wat to modified...
yes all proton car is FF. cos using 4wd g/b, that y need to lock it to 2wd, same as the evo u going to put in ur waja, also need to lock to 2wd...
so u found ur engine aldi not??? if not, than u see ur pm, i hv send sth to ur pm.
noeyedeer
91
izzit convert frm 1.6-2.0 still legal? tot can go to 1.8 onli.
gohkokeng
2,443
4
for me oppinion....
SAVVY so called built toughter also no use.......:Not_Impressed:
<p style="text-align: justify;"><img class="alignnone size-medium wp-image-10923" title="494593" src="http://www.zerotohundred.com/wp-content/uploads/2010/02/494593-600x399.jpg" alt="" width="600" height="399" /></p>
<p style="text-align: justify;">Volkswagen has revealed its much anticipated Polo GTI ahead of its official unveiling in Geneva next month and together with these pictures are almost complete details of the inner workings of this fifth-generation Polo GTI.</p>
<p...
