can 4g92p fit mivec throttle body?
wiramax
797
Hi zhtrian,
Need advice here.Can i install mivec throttle body to my 4g92p(1.6sohc) engine. FYI my car is with std 92p wiring & for 92p its use ISC throttle body whereby mivec t/b use stepper motor.I know if i change to 93 Dohc & mivec wiring it can be done, but it will be costly.Anyone has done this mode before?Hope u guys can share or advice.Thanks.
mr_lageenda
65
Hi zhtrian,
Need advice here.Can i install mivec throttle body to my 4g92p(1.6sohc) engine. FYI my car is with std 92p wiring & for 92p its use ISRC throttle body whereby mivec t/b use stepper motor.I know if i change to 93 Dohc & mivec wiring it can be done, but it will be costly.Anyone has done this mode before?Hope u guys can share or advice.Thanks.
i think u should see this picture.Maybe u can get the answer..
Clik this link
http://images.google.com.my/imgres?...rottle+body&ndsp=18&hl=en&sa=N&start=252&um=1
wiramax
797
thx for the info mr lageenda.but that dsm throttle body, its from evo 3?coz its stated 4g63.
wiramax
797
anyone has done this mod before?otai2 92p maybe?need advice.
JackWaiKit
262
5
www.friendster.com
I think it should have any prob...
4G9x series can simply rojak everything but of course it doesn't increase much WHP unless u do proper tuning.
No matter it's evo or 93, as long as it been upgraded, it calc by size...
But my advice is u better select 4G93 than Mivec...
Coz mivec is use Mapping sensor where urs is air-flow sensor!!!
wiramax
797
thx for the info.bt if i nt mistaken,93 std t/b is oni 54mm, n currently i m using perdana sei t/b which is 56mm.The reason y i choose mivec is bcoz their std t/b is 60mm.i m looking at option to chg to mivec t/b w/out changing the whole wiring to mivec wiring.But i do heard from frens dat it can be done.dats y i m seeking for anyone wo have done this mod before.
Zattara
244
I think better u change the throttle body to the performance throttle body...
JackWaiKit
262
5
www.friendster.com
maybe u can't do this...w/o changing wiring!
ur idling sensor at t/b will not fit with ur ECU...
unless u mod...
but wiring have to cut like sotong!!!
wiramax
797
ady fix evo t/b.prob solved.thx evryone.
thread closed
DON’T BUY NISSAN.
I owned a brand new Nissan Sylphy since August 2008. Until 09/04/2010, my car mileages run up to 90,000 km.(Car age: 1 year 7 month).
The quality problems I having so far as below: -
1) Dashboard has bubble spot - changed on January 2010 - problem solved – reason given was Japan and Malaysia weather difference.
2) Complaint on suspension noise - when turning and on uneven road (since 2nd service
mileage 6710 km until 89,994 km). NOW 90,000 km only solve the...
