alpine W502
DVD / CD receiver with touchscreen and internal amp 7″ ( 50 peak x 4 channels )
• Double – Din Chassis
• Plays CD, DVD, recordable discs ( including discs loaded with MP3, WMA, or AAC files ), DVD + / R / RW
• Video CD and Divx compatible
• Dolby Digital and DTS digital output via optical cable
• Compatible with Alpine PXA – H100 IMPRINT ™ audio processor
• Compatible with Alpine iPod adapter, Bluetooth adapter, CD Changer, Navigation module, and surround-sound processor
• USB Input, A / V input, Rear Camera Input
• A / V output, optical digital output, 6-channel preamp outputs ( Front, Rear, Subwoofer )
• Bluetooth ® Ready ( optional KCE-350BT or PMD-B200 required )
• Full speed auxiliary input to mini-jack cable ( optional KCE-236B required ) ? Remote control included
• IMPRINT ™ Ready with dual input capability ( PXA-H100 audio processor required )
Spesificasion:
Highlights
- DVD / CD receiver with 7 ” touchscreen and internal amp ( 50 peak x 4 channels )
- Double DIN Chassis
- Plays CD, DVD, recordable discs ( including discs loaded with MP3, WMA, or AAC files ), DVD + / R / RW
- Video CD and DivX compatible
- Dolby Digital and DTS digital output via optical cable
- Compatible with Alpine PXA-H100 IMPRINT ™ audio processor
- Compatible with Alpine iPod adapter, Bluetooth adapter, CD changer, Navigation module, and surround-sound processor
- USB input, A / V input, Rear camera input
- A / V output, optical digital output, 6 ( channel ) preamp outputs ( front, rear, subwoofer )
Connectivity Features
- DVD-R / RW / CD / MP3 / AAC / WMA / DivX playback
- Direct USB and / or Full Speed Connection ™ for iPod ® with album art display (if available)
- IPod video control for select iPod models
- USB MTP support for MP3 players, mass storage drives
- Bluetooth ® Ready (optional KCE-350BT or PMD-B200 required)
- Full speed auxiliary input to mini-jack cable (optional KCE-236B required)
- A / V input / output, rear camera input
- Single-zone rear seat output with independent source control
Control Features
- 7″ WVGA touch screen display
- Quick Search ™
- Steering wheel remote ready
- Remote control included
Audio Features
- 24-bit DAC
- DVD Audio 2 ( channel down-mix )
- DivX, DVD / R / RW playback
- Full processor control
- DTS ®, Dolby Digital ® and Dolby Pro-Logic II ® support
- IMPRINT ™ Ready with dual input capability ( PXA-H100 audio processor required )
- Power Pack Ready ( optional KTP-445 amplifier upgrade required )
- 3 pre-outs (2V), subwoofer level control
- CEA-2006 Power Ratings: 18W x 4 RMS
iPod Compatibility
Full control and charging for:
- IPod 5G
- IPod nano 1G – 4G
- IPod classic
- IPod touch 1G and 2G
- IPhone and iPhone 3G
___________________________________________________________________________________
alpine W520
Max Power Output Ratings
* Max Power Output: 4 x 50 W
FM Tuner
* Tuning Range: 87.5-108.0 MHz
* Mono Usable Sensitivity: 9 dBf (0.8μV/75ohms)
* 50dB Quieting Sensitivity: 12 dBf (1.1μV/75 ohms)
* Alternate Channel Selectivity: 80.0 dB
* Signal-to-Noise (S/N) Ratio: 60.0 dB
* Stereo Separation: 30.0 dB
* Capture Ratio: 2.0 dB
MW Tuner
* Tuning Range: 531-1,602 kHz
* Usable Sensitivity (IEC Standard): 22.5/27.0 (μV/dB)
LW Tuner
* Tuning Range: 153-281kHz
* Usable Sensitivity (IEC Standard): 31.6/30.0 (μV/dB)
Connection for USB
* USB Requirements: 1.1/2.0
* Max. Power Consumption: 500mA
* USB Class: Play From Device / Mass Storage Class
* File System: FAT 12/16/32
* MP3 Decoding: MPEG-1/2 AUDIO Layer-3
* WMA Decoding: Windows Media™ Audio
* AAC Decoding: ACC-LC format ′′/m4a′′ file
* Number of Channels: 2-Channel (Stereo)
* Frequency Response: 5-20 k ±1 dB (Frequency Response may differ depending on the encoder software/bitrate)
* Total Harmonic Distortion: 0.008% (at 1 kHz)
* Dynamic Range: 95 dB (at 1 kHz)
* Signal-to-Noise Ratio: 105 dB
* Channel Separation: 85 dB (at 1 kHz)
Disc Player
* Channel Separation (1kHz): 65dB
* Dynamic Range (1kHz): 95dB
* Total Harmonic Distortion (THD): 0.02% (at 1 kHz)
* Wow & Flutter (%WRMS): B.M.L.
* Audio Signal-to-Noise (S/N): More than 95dB
* Signal System: NTSC / PAL
* Horizontal Resolution: 500 lines or greater
* Video Output Level: 1Vp-p (75 ohms)
* Video Signal-to-Noise (S/N): DVD: 60 dB
Sound Tuning
* Subwoofer Level Adjustment: 0 to 15 Step
* High Pass Filter: OFF/80/120/160Hz
* Bass Level Control Range: -7 to +7
* Bass Center Frequency: 60Hz, 80Hz, 100Hz, 200Hz
* Bass Band Width Adjustment (Q): 1 to 4
* Treble Level Control Range: -7 to +7
* Treble Center Frequency: 10kHz, 12.5kHz, 15kHz, 17.5kHz
