Brembo brake different ?
cmng
3,289
72
Just like to check any different between the Evo 5-9 Brembo caliper and rotor ?
for front brembo
your help is much appreciated
norick
110
39
yes, MirageAsti is right..
But its only the piston is slightly bigger,
the body of caliper & rotor still remain the same..
cmng
3,289
72
ok.. great
from my survey i checked rotor is same for all generation
but for caliper i not sure
in this case you all mention caliper wise , mounting all same between E5-9 except the E7-9 piston is bigger than E5-6
overall i can assume a E5-6 caliper can bolt on to E7-9 as well
the different is come from piston which translate the Piston Service Kit is different due to piston
am i right ?
TQVM in advance
kampoon
1,205
89
where you plan to plant the brembo into ??
kampoon
1,205
89
kampoon
plan to fit on silvia
it hard to source those nissan brembo
Of cause the latest one is better, i think it might have some minor improvement on each version, but for your case, just get E 4, 5, 6 will do.....for cost saving and easier to source ......happy modding
I'm buying adjustable pulleys for my Colt Gti 4G93 DOHC with CAI and exhaust 2. 1/4", searched topics in the forum but have found.
Want to know what the best setting to increase the peak power at high rpm?
Can increase the peak power of the 140hp @ 6500 rpm for a rotation greater than 7000 rpm?
How many degrees do I need to forward the admission and how many degrees late to escape, have a higher peak power at high rpm?
Looking forward to the best setting.
