Brembo brake different ?
cmng
3,289
72
Just like to check any different between the Evo 5-9 Brembo caliper and rotor ?
for front brembo
your help is much appreciated
norick
110
39
yes, MirageAsti is right..
But its only the piston is slightly bigger,
the body of caliper & rotor still remain the same..
cmng
3,289
72
ok.. great
from my survey i checked rotor is same for all generation
but for caliper i not sure
in this case you all mention caliper wise , mounting all same between E5-9 except the E7-9 piston is bigger than E5-6
overall i can assume a E5-6 caliper can bolt on to E7-9 as well
the different is come from piston which translate the Piston Service Kit is different due to piston
am i right ?
TQVM in advance
kampoon
1,205
89
where you plan to plant the brembo into ??
kampoon
1,205
89
kampoon
plan to fit on silvia
it hard to source those nissan brembo
Of cause the latest one is better, i think it might have some minor improvement on each version, but for your case, just get E 4, 5, 6 will do.....for cost saving and easier to source ......happy modding
The upcoming 2012 BMW M6 Coupe (F12) has been creating quite a buzz on the internet, and while the M variant of the new 6-series is still some ways away, some graphic designers are already coming up with their best guess of how the new M could look like.
These rendered images were posted on bimmerboost.com and takes its cue from the BMW Concept 6 Series Coupe which BMW will be premiering at the...
