Boost Meter - Mechanical type?
Pakdamek
158
22
518
Hi...
I don't know if this is a dumb question or not. But I still wanna ask you guys.
What is the difference between mechanical & non-mechanical boost meter?
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
mechanical need boost small pipe to directly connect to meter... (the small pipe like vaccum from turbo)
EL type need that pipe to connect with sensor..then sensor only joint at meter with wire.....
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
not sure about that....
if me i prefer mechanical type..less part that can be faulty (easier to trace)
and less messy wiring?
:adore:
but it just me....maybe other ppl got their own opinion...
Aiyah, anything also got pros and cons one. Just see the owner like what only....:biggrin:
basikal_pancit
603
54
3,028
Selangor
I had used both mechanical and non mechanical.
Both also same brand, APEXI.
Non-mechanical (electronic)-
Like :
1. the jarum will move when u start the engine (like DEFI)
2. can record the highest/lowest boost
3. NO hose behind the meter, just a small wire going to the controller
Dont like :
1. the sensor usually place inside the engine - easily to spoil due to heat
2. more expensive (have to buy controller some more)
Mechanical
Like :
1. sensor in the meter itself, so can last long (no heat)
2. cheaper and more choices
Dont like:
1. hose coming out from behind the meter, depend on the location u place the meter, sometime can be disturbing.
2. cannot record, no moving jarum when start etc
I was cleaning my car speed meter and rpm meter plastic surface with microfiber cloth. But cause some minor surface scratch
Scratch level: finger or nail can't feel it, but can see the minor scratch from side reflecting
dear forumer, any solution i can remove the scratch?
