Battery always running low?! (RX7 FD3S)
fanjun93
23
1,503
Tokyo, Japan
Anyone knows what could be the possible reason of my FD keep on running on low battery? It's always hard for me to start the car in the 1st drive of the day because the battery level is low. And everytime when I need to start it, the ignition takes atleast more than 4 tries.
fanjun93
23
1,503
Tokyo, Japan
I've got the technician to check it, it seems to be working properly yet the battery is still always running low.
Alchemis
1,416
47
there are leakage... check for any wire exposing... like your head lamps...or some burnt electronics components.. which is almost impossible to find ahahhaha..
just start your car everyday.... my car also happens to cough like old man if i start once a week... after a drive.. it has more than enough power...
Rock Lee
3,972
25
Klang, Selangor
www.rockmotorsport.com
or if yuu're hardworking enough.. remove the negative terminal of your battery everynight and plug it back when u wanna start.
or change to a bigger size battery NS70.
probably u can install a standard volt meter to keep your voltage in check, see if your alternator is charging the battery enough.
If you wanna check for any open circuit, wire exposing, remove the positive terminal in your battery, get a bulb and connect the 2 wire at each end. make sure all your doors are close, if the bulb lights up probably there's an open circuit. not sure about this trick. I tried it myself once.
or you can get those voltage management system.
xtremeleo
3,247
464
there is current leak sumwhere sir, u need to trace it out.pm for more details, tq
JINEIL2EN
15,317
525
Island Of Pearl
team99ers.2.forumer.com
ur alternator working, but not enuf charge for ur batt, consider 'half kong' dy.... ask ur mech replace another alternator for test a few days... FOC ofcos...:proud:
ehdrian
I Don't Care!
3,310
280
1,683
is your batt relocated to the back?
is this a symptom of battery relocated to the back?..mine is also relocated to the back but it doesn't hv prob like the thread starter, only fluctuating voltage readings when idling(frm 13.8v-12.4v)..
hi guys.....i need ur help
i'm using a 4mth old iswara lmst
this morning car couldn start......mechanic check n said battery died. replace to a brand new battery. i have dis problem....when my car is idle, battery light comes on.....but when i rev up it goes off.....can anyone tell me wats da problem? could dat be the cause for my batt to die within 4 months?
