anyone locally having crank shaft problems with B6 big manifold???...i just snapped by second one...again at the main pulley only...TU-LAN !!!...i remember reading about it somewhere in the net but ostly all experineced by people overseas...
KURT,
is yours a miata or the B6???...some say the B6 small manifold has the improved crank with the bigger crank nose...i haven't seen it yet so i can't confirm...however according to your article only the 91 models onwards has that crank but B6 last production was in 89/90 after which was the BPT...but i am replacing mine with a miata crankshaft which has a bigger diameter crank nose...not sure what year coz it came in an engine kosong...hope it works
mine is a miata 1.6 .. miata also b6 and b8 but non turbo.. but then it can used turbo b6 and b8 parts also..
the problem with the crankshaft is for miata year 89-91 only..
you bought a miata engine kosong or just the crankshaft only?
came in the engine kosong but physically comparing both the crank nose...the one in the miata block a lot bigger than the one from the B6...if yours is the pre 91 model i guess the B6 small manofild also has the same problem...except i havent heard of any B6T snapping any crankshaft except mine so far...
coz they didn't sell the crank only...had to buy the whole block...you have a spare to sell???..what do mean buy long block and short block???...or izit just a term used???...i know the compression ratios between the small and big manifold are different...but bore and stroke are the same...maybe piston offset different...
Many of us having problem to repair our car from one workshop to another workshop. Many workshop now is hire those who have certificate but not enough experience.
However, I still choose a workshop have good experience, I don't care how many certificate they have.
Air Cond Workshop
Anyone who stay near Jalan Ipoh.
Good poor engineer, you may not interested to repair a car here once you come here. This guy is buddism he will not cut your neck...
