Atr turbo stock camshaft using adj cam pulley
stutzedward
3,416
561
When I upgraded my cams to Evo 6 ones, I was being told by our expert Airtrek mechanic (Ah Wah from Kinrara Puchong) that using cam-pulley on stock Airtrek cam will not help. The degrees and lift is not high enough to benefit the advantage from the pulley. If you're on Evo cams, then yes. The degrees for evo-cam is 260 for inlet and 256 for exhaust.
Airtrek-R
Sep 3, 2012
30
6
508
Penang
good info... what are the duration and lift for stock airtrek cams?
stutzedward
3,416
561
I can only find cam degrees for Evo ones. No info on Airtrek cams. The chart below which I found.
one_piece
18
1,503
whatis the best adj cam pulley atr suggestion???
huhuhuhuuhhh....
Thanx
stutzedward
3,416
561
Works is pretty good if you think that HKS is expensive. Don't get those imitation ones.
stutzedward
3,416
561
Yes. Bro 4gbanger can advise. He has Evo 8 cam + Evo 3 springs. Ah Wah said they are the same (springs)
Poacher
85
18
508
Auckland, NZ
Is there anyway to tell if evo 8 cams a genuine? Like number written on cams? Also is springs (evo or after market) recommended up evo 8 cam upgrade on airtrek, thanks
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
i did some research about evo 8 cams.. there's not much of difference. only some minor different on the shaft itself. but alot of different on power output.. i'll sure put a smile on ur face.. check out the pic i post on other thread in this forum..:biggrin:
---------- Post added at 04:25 PM ---------- 6 hour anti-bump limit - Previous post was at 04:23 PM ----------
u can use camshaft from evo 6 to evo 8 as written on stutz's attachment up there.. but u can use valve spring from evo 3 till evo 9 no problem.. better get one before install the camshaft. if not u'll be paying ur mechanic 2 times.. :biggrin:
---------- Post added at 04:27 PM ---------- 6 hour anti-bump limit - Previous post was at 04:25 PM ----------
huhuhuhuuhhh....
Thanx
i think better buy the works campulley.. slightly cost than imitation but alot cheaper than japanese aftermarket..
---------- Post added at 04:30 PM ---------- 6 hour anti-bump limit - Previous post was at 04:27 PM ----------
seems like our stock cam spec is wayyyyy lower than evo's.. so i think its around 240~248 deg the most.. changing to evo cam will increase power alot than u think.. rite stutz?:biggrin:
Do 4g93T have clutch pump? I found that my clutch oil is getting lesser, and clutch is getting harder sometime also. So i checked underneath car, i found there is leak at some where rod joint there.
So i went to mechanic and check, they claim that clutch pump failure.. so just want to make sure there is clutch pump for 4g93t? And does anyone know can i just/manage change the "rod joint" to prevent leak? any sifu experienced tis before?
