Apexi RSM
zzainudin
503
Subang selangor
hi all zth sifu's..
got 1 question about Speeding Meter ..
mine RSM Speed reading got very big gap (analoq Vs Rsm)
Analoq 50kmh but RSM display around 100++..
i know RSM can give the acctual reading compare to analoq meter
but why n how to set it to normal or maybe my RSM 'KONG!'
any idea..help!!!
Thanks
kennethfong
506
just a suggestion, i haven't had such symptoms in my rsm, but try check the setting esp the cylinders setting, but couldnt be me think that's jus affect the rpm... anyway just double check.....
zzainudin
503
Subang selangor
Bro kenneth..cylinder setting set to 4 clyn..dont know why, REV Reading ok..
now Monitor display set to 2 channel, rev & speed only..
for ur info i put together safc2 D1 spec and Rsm D1 Spec..
vitrous
169
Pahang
woh...so high la the reading..
so..if u drive about 150..
ur doing 200..hahahaha...
mine at first are just 20kmh gap...
but when send to the mechanic..
it was all abt the wiring..
consider i bought the car 2nd hand..
zzainudin
503
Subang selangor
not la bro vitrous..maybe if i drive around 150kmh the meter display i think around 280kmh maa..hahaha
anyway wait for tomorrow, i'll check it again..
maybe if u all got the tip plzz advise k..
Adeen
2,726
6
kl
have u programmed it with the right size of rim/tyre...?
zzainudin
503
Subang selangor
oopss...i dont think so..
bro Adeen, where can i find the setting...
thanks bro i'll find it
Adeen
2,726
6
kl
if u do find it....please state whether ur problem solved or not...:)
m1adam
258
wheel size does affect ur speedo reading wat is ur wheel size?
zzainudin
503
Subang selangor
i'm using 205/45/R16 tyres...
how the diameter?
Formula from manual apexi
Corr. Value = New Tyre Dia x 100
Factory Tire Dia
so if std wira come with 175/60/R13 right..
The Marketplace Top Posts
Paging Madman, paging Madman, please share your DIY radiator flush with coke here. I'm curious to know the history and reason behind using coke and how well it worked!
