Altezza SXE10 Rear rotor size
RScosmic
Jul 23, 2010
10
503
Singapore
Hi, can any bros advise, Altezza SXE10 rear rotor is 291mm or 307mm?
Apparently, when you key ion the rear rotor in it states 42431-53011 which is 307mm.
I did found another web which states 42431-51010 . SO can't differentiate which is the correct one.
Can any bros advise?
By the way I'm driving a 2003 Altezza 5AT.
green
326
25
3,028
kl
most probably yours is a 3sge since its a 5speed auto.
rear disc rotor is 307mm diameter x12mm thickness
Greytezza
1,130
68
1,648
Truly Asia
Mine was a 1G ler in a 3s......., i guess mine was a rear one
Steven..:adore: your car really is very "special"...from the interior accessories and now the mixture of car parts from 1G...any more surprises for us..:rofl:
stepwyew
448
15
Got......
No antenna like what you have hahahahahahahaha
cheers..........:beer:
Beading Effect for KKE Thick Wax -
When water is sprayed on a normal car surface, the water would generally form a film and remain on the car paint and would probably dry on the car. The water drying on the car has several problems like leaving water spots, dirt dryin on the car etc. Even harmfull effects of bugs, tree saps, road film harms your car paint and its finish.
An unprotected car paint would probably have a water film.
KKE Thick Wax is to be applied by hand using a wax...
