Altezza idle rpm
mrs88
43
1,508
Y mine turn up to 500rpm only ah..some more d engine vibrating too.is there any thing wrong with timing..o probablybd eng mtg wear out d..
rayncc
26
1,503
500rpm is low. Get the throttle body serviced and the engine properly tuned up
ColdPlay
288
112
1,543
Something is wrong when the idle rpm is barely 500 on 2.0.
Engine mounting issue usually associated with loud engine sound intrusion into the cabin and vibration, regardless of engine speed where higher engine speed caused vibration too.
As mentioned by rayncc, start with tb cleaning. If you stay around KL area. Mr Alex in Desa Tasik or William at Trial Tuning Sungai Besi are the best person to find. Both are located less than 2km apart.
hallo...if i wanna do some modification on this, do suggest me what kinda throttle body should i use to replace this stock throttle body...help plz... :adore:
