Alarm issue PLEASE HELP ASAP
shhendri
7
I have a King Eagle alarm. I took my truck to get detailed, when they were finished the truck would start by remote but would suddenly died, the key will not start the truck. The status LED lights are on solid, the remote works, I disconnected the battery over night, tried turning valet on and off. Now it wont remote start or key start. Is there a way to disengage the ignition kill?
Please HELP.
Gti
1,106
8
u know what i did last time?
i took off the whole thing..
not the best solution but at least it works..
all the best mate
maybe u can try speak to ur installer
spec.check
141
Please HELP.
Shhendri,
Where did you install your alarm unit?
regards.
shhendri
7
No issue with alarm, the guy who detailed the truck got water in a fuse box blowing a fuse and making it so the alarm couldn't recognise the ignition.
jkn
92
Can anybody tell me which fuse? I'm having the same problem now. HElllpppp...
Dremel said:
any rough suggestion for proton satria ? i'm not sure whether mine is 6kg(F)-5kg(R) or 5kg(F)-4kg(R).. does there any label of spring rate printed on titan's spring? coz Richard seems doesn't have the record.. coz mine is 2nd hand. The only thing that he said was.. 'wah.. your spring is quite hard'
I assume mine is 6/5 or 5/4 is because i got 2 friend running on 4/3 which are sgti and putra. Theirs is abit softer than mine.. with same damping settings.
Hi
As for...
