Air Filter Installation
cfpang
12
I'm driving wira aeroback 1.5 special edition....i have just changed my air filter from original to K&N 3" type air filter. I just want to know do i need to tune my car after change tis filter....Thank you
SkYwAlKeR
10,139
300
ePoh ~ malacca
ur car is efi or carbie engine??... if carbie, better tune ur A/F ratio lar... coz more air is being sucked in, u need to recalibrate the air and fuel mixture....
if efi, no need i guess... ur car ecu will recalibrate itself... if u insist of tuning it, jz reset ur ecu, it will reprogram itself.... no worries...
gohkokeng
2,443
good point here.......so do my concern.....
my LMST just upgraded Apexi open port....my air/fuel RPM at 1300 with and without aircond
so u guys think is ok or not? too high?
nitrus
2,895
35
skywalker, how to tune the A/F ratio ar? issit the same as tuning the carb rpm idling that screw? or are they the same thing..?
gohkokeng, its quite high.. ask any shop set it back around 850 if possible.
SkYwAlKeR
10,139
300
ePoh ~ malacca
not same lor... normal carburettor has 3 screw...
i) tune idle rpm when aircond off
ii) tune idle rpm when aircond on
iii) tune A/F ratio....
how to tune... i also not vr sure... this have to ask sifoo sifoo in carburettor section....:regular_smile:
roy27
164
for carbie is very easy to tune ma.....there got 2 screw thingy.....1 screw (using x screwdriver) which located under the carb air filter is 2 adjust rpm without AC......n 1 more screw located neat the AC compressor (gold in colour....which can use finger to turn it)......tis 1 is to set rpm when AC is on
EFi can't DIY tune ler
gohkokeng
2,443
nitrus
haha i sendiri set it 1.....really too high? then maybe later set back myself loh..
SkYwAlKeR
1st and 2nd i know where and i did tune it myself....about the 3rd 1.......haha what is it for and where it is located at?
roy27
164
pls share here if anyone knows how to set the AF ratio.....its for benefit of all carbie n efi user....
cfpang
12
thank you skywalker and all others guy for your good information. My car is a 1.5 injection so tats mean no need to tune right? but from wat u state the ECU can be reset in order for it to recalibrate...but can i know how to reset it.....
roy27
164
take out yr batterry cable from yr battery n then leave it like tat for some time.....some ppl say leave it for 2-3 hour, few hour n oso say 12 hour b4 u put back the battery cable.....hehe for better purpose better if leave it for 1 day if u dun use car.....any other opinion from other member?
tuckz
151
I have a proton wira 1.5 fuel injection
It is the 2001 edition
I went to the shop to change to a open air filter (K & N or HKS)
But the guy say my ECU is troublesome
If i change the filter, excessive air might cause my engine to shut off
It is due to the Siemens ECU or something?
Can someone confirm on this
Because i heard that changing to open filter will create more power and nicer sound
edwin_lcw
1,242
Setapak
no such thing your ECU is self-convincing programing ...... it'll change its setting its own until it's convinced thats the best setting ..... from what i understand la ..... many dudes here using siemens ECU nothing ar ..... olso open pod filter
cfpang
12
Mr Edwin so wat you mean is after change to open pod filter we no need to tune anything the ECU will self-convincing OR need to take out the battery cable for it to recalibrate..
tuckz
151
Oh and my wira is 1.5 auto fuel injection
That's what i hope but the guy said that the older wira no problem
But the new wira with so many wires and controller is more problematic
I have another wira 1.6 auto fuel injection
The engine is really different
So im not sure if my wira 1.5 should take the risk to change the filter
Will it be worth it?
I'm new in using car sticker. I've attached a picture to show the problem I faced when sticking car sticker. Pls any SIFUS can help me...Thanks
