imoloq said:
Wah that means there's lots of ADR monsters around wor!
Yes I've seen a Sentra B14 converted to SR20DET using back the suspension of the Pulsar halfcut so most likely I'm going to do that. But will the Pulsar suspension fit the ADR? If need custom work then the cost will be higher.
Why I say it's undrivable. Cause a long time ago I wanted to change to SR20DET already but my mechanic advised me not to cause the weight of the engine will cause it to be too nose-heavy and thus hard to control. Maybe will understeer a lot too....
Thanks for the tips
ok , now i know wat u mean. for the rear suspension u need to put some $$ to custom the absorber n the coil. small matter onli.
if the engine cause u weight , to overcome it just install the suspension sys from the half n ur problem is solve. if u say the nose is heavy then the engineers from japan is useless. no worries , i think u should install the suspension system from the halfcut first. if u think is not too suitable then look for adjustable absorbers.
hard to control ............if the engine is too heavy with low horsepower the car will b for sure hard to control. now ur car is about 200++hp and u need a better suspension sys (performance) so that u can control the car.
i realy recommend sr20det riders, to install 17" rims. this is cause ur engine torque(pickup) is very strong when the turbo kick in. just recommend onli.
if u have any problems do feel free to give me a call at 012-3355 352 ( tannie tam)
andy : so this sr20det monster 16" with 60 series tires will make the car sway from side to side more coz the tire is too thick. they need low profile tires so that they can grip more during corners. in the other words give more stabilty.
