I have the oem fuel pump taken out from my car... you want??
your stock pump is not enough coz of your mods?? then you will need to upgrade your pump and not use back oem pump.... btw, the only way you gonna need bigger pump is if you go fi....
got.... get Denso pump...... direct fit....
there are many sizes to chose from.... oem pump is Denso....
158 on wheel is bad for your car
we get 170-180 on wheel
On wheel??? Are you sure?? The car standard rated hp already 180hp on the flywheel. How can you get 170 - 180 on wheel??? Mods??
bone stock is about 155-160whp for manual.... auto is about 135whp...... some mild bolt on mod will get you to 170whp easily.... there are a few 6speed out there with more than 200whp already....
190whp NA? not easy lor... with our ultra hot air temp here and RON97 fuel.... and you will need lots and lots of cash too..... we are talking RM30k to RM40k here..... that will get you near to 190whp.... BUT.... with this amount of money, you could go boosted with a built engine and easily get 400whp..... :)
Similar threads | |
