4g93 need help!!!
wirasemput
Jul 15, 2010
22
Hi all sifus out there,i'm using 4g93 rojak one...stage 1 pnp+288 in/ex matspeed cam,4-1 header,2" straght pipe, full ballancing+std 93p piston+acl+lay abit my crank+alloy crank pulley+3 puck exedy+4g15 g.box...just install it a month a go...whithout install any mngmnt or rechipped ecu(my ecu code is 6553 4g91 (a)if not mistaken)...
now my prob is got knocking...
my questions is,
1)what size of t.body should i go?
2)which AFC is better?evo or any suggestion?
3)which 1 better either emanage or rechipped ecu?
4)is my exzos setup in correct size?
please all sifus out there,help me...:adore:
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
**b16a ones
**SAFC
**emanage, if no bajet - haltech E6X
** beter 1.86"
wirasemput
22
thanks bro DanzEterna...
actually,i think my q no2) is wrong...
AFC,i'm asking bout air flow censor unit... now i'm using 449,HKS mushroom,std plug cable,NGK iridium plug,ecu 5663,injector now 240cc+fuel regulator...
around 3k pluss rpm in 5th gear sound "crit,crit,crit " coming...
plug colour last time,lite brown one...:hmmmm:
slipar
500
61
banting - pj
same prob as my friend doing the same modification..
try using my 275 injector then problem solve..
but maybe something else..
just sharing..
slipar
500
61
banting - pj
275 from v6 engine..
seen it in marketplace..
half cut maybe selling set of 6..
good luck in searching..
wirasemput
22
Thanks dude...hope i can find a set...
after install it,management,got emanage in mind:hmmmm:
end of this month hope so...:slug:
93na
597
20
walbro fuel pump will help, not using metal gasket???.... honda intake skunk tb, safc, better fuel railing,rechip will do, if got extra cash do like wat danz said! then vtec piston! sufe car will take of for a 4g93 na
happy modding
wirasemput
22
happy modding
now i'm using honda fuel pump,not sure witch model.... now using 0.5mm thickness,
if i'm use like work fuel rail+walbro,it's can help to resolve my prob?:stupid:
honda intake n bigger tb got in my mind,but no budget lor...
bro danz said???huhuhu,emanage ok lor,but ex6 wallauweh....:bawling:
---------- Post added at 03:59 PM ---------- 6 hour anti-bump limit - Previous post was at 03:55 PM ----------
....then vtec piston!
if i had done full ballancing,is't possible to ad any more like piston???:hmmmm:
---------- Post added at 04:03 PM ---------- 6 hour anti-bump limit - Previous post was at 03:59 PM ----------
---------- Post added at 04:09 PM ---------- 6 hour anti-bump limit - Previous post was at 04:03 PM ----------
how bout now if i'm only replace my injector to 275cc,65mm tb with std intake, then install emanage?
rasional all sifu???:idea:
slipar
500
61
banting - pj
if u plan to install piggy back then install it 1st better..
when tuning the piggy back u can pin point which part u need or can upgrade base on d tuning data..
then other upgrade just retune the piggyback to suit ur driving..
Mrnazmi
510
29
3,028
Drag City
Go for Super 90 - 70mm T.Body, if can get together with Skunk2 Intake, then should be more advantage. (need to add some plate to put the Skunk2 Intake at 4g93 head)
ACF Neo (for tuning) The air flow sensor ok 449.
Re-chipped Ecu, more advantages (cheap and easy to tune)
Maybe can try change to 2.5" straight pipe
p/s: Dont forget to install adjustable fuel regulator also.
Use high quality spark plugs (NGK-R)
Upgrade injector to 275cc.
Change cable plug to power cable plug.
Hope others can add more supportive information. Tq.
wirasemput
22
Thanks to bro 93na,DanZ,slipar&Mrnazmi for da advice...
any suggesstion???
if i goes to rechipped,where should i go???
coz lately emanage got so many immitation one...scared la....
93na
597
20
alot of place can go bro for rechip that racedude, my forman also does it! try going to marketplace and look! there lots of brand and type all i would say almost the same la!
Featuring refreshed exterior styling and upgraded interior, the new CLA comes in 3 variants, namely the CLA 200, CLA 250 Sport and the high performance AMG CLA 45. The new 4-door coupe is priced from RM234k all the way to RM409k.
Mercedes-Benz CLA
Engine:
CLA 200: 1.6-litre 4-cylinder, turbocharged; CLA 250 and CLA 45: 2.0-litre 4-cylinder, turbocharged
Power:...
