- Jul 30, 2006
- 118
- 0
- 1,516
eemm seem all using 4e inside charade can i join? im using 4e to.. lots of tech info bro nice see..how many r u dat using 4e?
Dawg : actually spacers are not recommended especially if you frequent high speed as they made on-car alignment a nightmare, correct me if i'm wrong.Dougster said:The deto rims are 14"...i dont forsee a problem fitting the rims in.... YOU MAY have to get spacers for the front to accomodate the calipers...MAY....spacers are cheap anyway....
Speedy : With all that said, DOES THAT MEAN 4E front disc brake can be fit into Aura G100 / G102 ?!Speed Demon said:5. The 4E comes with disc brakes which are larger than the CB23 front and of course the CB23 rear is drums. So you must be using 14" rims & tires or larger
FCUK and double FCUK. Thanks Dawg.Dougster said:and tibun....Yes the 4e brakes can fit....but im not sure if their compatible with the aura stock absrobers...they'll probably need to modify the mountings...coz im using the starlet absorbers and the brakes are a perfect fit lar..
yes, FYI, any gaugeis the same. get the wiring part done right and the gauge will work fineDougster said:Jamil ..arent u using the 1.3 fuel tank?
if not..then ur using ur cb-23 tank with the starlet fuel gauge ar?
d thing they sent wasnt ur drive shaft, it was the lower arm. mod was crucial to accomodate ur new disc set, not much was done though.. i think they only had to mod a ball joint in, or sumthin.. ur main engine mounting is still using the g100's, others have to mod but u cant tell because 4e mountings r like wira's, they r screw type and can be removed if necessaryDougster said:Btw,,,jamil.....they did send my driveshaft to the machine shop.....and they did have to weld in the new mountings...but their in almost the same location as the mountings on the CB23 block...
Tezt...Kl? we'd have to find a day then..hahaha...if u can, why dont meet us in sunway (i know its far), a few of us are meeting up on saturday morning near pyramid....just fyi....
About me using rear drums...lets just say the finances are a little tight now...hahaha...got to do things one by one...but i'll be sure to get the discs settled when the time is right.... I've got to take care of a host of other things first before i go there... :)
The deto rims are 14"...i dont forsee a problem fitting the rims in.... YOU MAY have to get spacers for the front to accomodate the calipers...MAY....spacers are cheap anyway....so its not much of an issue...but apart from that, ur 14"s should be more than fine....
