i also would like to know the outcome of 2zz vs. 3sge......
1 question on 2ZZ
any1 use b4 power fc on 2ZZ??? can it control the vvtli open earlier??......last time i test drive a few 2zz and it open only at 6krpm,,,,correct me if i'm wrong......
there are a few 2zz guys running on pfc..... some running lower Lift point and some higher... depends what cams you are using... pfc is meant for manual only but can be hooked up with Brashboy harness to the auto 2zz and work as a piggy back.....
I can feel small jerking while slow acceleration of my car. While cruising, OK. What I know jerking is caused by:
1) spark plug cable (relatively new 1 month)
2) fuel filter (about 6 months old)
3) distributor (change new one 3 years ago)
4) spark plugs, air filter (all new, just serviced my car)
What else should I consider? I am thinking about the fuel pump (inside the fuel tank). This is since it never get changed, still using original one, the car already 18 years. Should...
