1JZ-GTE Engine troubleshoot
nick4jc
5
Guys recently i did a conversion for a GX81 to a 1JZ-GTE from a JZX81.. The halfcut comes with full dash and full wiring from engine to the back of the car not splice.. :driver:
Now after finish with the full conversion including all wiring and finally the car be able to drive and i found out that the car seems to have some engine miss up to at around 6krpm to redline.. I can onli know this thru listening to how the exhaust sounded.. I tried changing the 1JZ fuel pump to new bosch 255lph.. still the problem is there.. at idle the car run great, when drive the car has no hessitation.. just the car feel a lil miss up to at 6krpm to redline.. its on standard boost 0.7bar.. so basically its all stock nothing has changed at all.. and by the way its an auto too..
Have anyone has this problem b4 and know what seems to be the cause..?? BTW the engine is VERY new the engine has no carbon at all its very new and clean.. So GURUS pls help if can.. thanks...
Nick
renxun
1,138
37
1,648
change spark plugs first.... then check your fuel filter.. if problem still there, check your fuel lines, clamps and your fuel hose. lastly check your regulator if problem stil there...
hmm ... can diy a clock using a disc brake arr ? :huh: hahaha ... wanted 2 get a disc brake clock bt cant find ne ... ne idea here where got selll arr ... or else go diy 1 .. go get a disc brake bek n do .. hahaha
