Advantage & Disadvantage to replace the Aluminium lighten Crank Pully
ericgtmythos
184
13
Kedah
Hello all sifu here,:itsme:
I have some doubts to confused me to decide replace the aluminium crank pully instead of original crank pully...??:confused::confused::hmmmm::banghead:
For some experience sifu let me know the comparison as below:
Advantage:
1) Will improve engine torque....coz lighten make the pully turning fast..
Disadvantages :
1) Lost the crank balancing, in future may be the crank bearing will facing un-balance friction..
2) Unknow or Un-estimate damage causes....to crank or related portion..
So i would like to asking more suggestion & opinion for those sifu who have experience to use the lighten aluminium crank pully on your 3S-GTE before...
Dozo Yoroshiku....:adore::adore:
Thanks for advice:ciao:
ericgtmythos
184
13
Kedah
Hi bro Bar,
Why like that :hmmmm:??...have u try before & worst result for side effect??
Thanks for sharing...
zeus83
981
55
KL-Damansara
wat cam pulley u intend to use bro eric?
im planing to go works or hks cam pulley, maybe camshaft as well....still undecided :hmmmm:
zeus83
981
55
KL-Damansara
Barbarian
625
24
3,018
www.myjsoc.com
unbalanced crank pulley causes alot of 2zzge engine to go kaput..... the first thing to go is the oil pump gear.... will shatter to pieces and if the car is not stopped immediately, engine kaput.....
I've got aftermarket oil pump gears so it was fine for me... :) but I removed the aftermarket crank pulley after a couple of months as the benefit gained is not worth the risk.....
xtremeleo
3,247
464
5,183
as i suspected, it causes unwanted vibration. it was wise of u to remove it sir
har1th7
375
42
for crank pulley... its base on the usage...
for NA car - can be used to free up some extra rev
for Force Induction - not so much power gain compare to piping , downpipe, & IC upgrade...
since ur car is 3sgte.... u won't feel significant power gain, maybe later feel frustrated...
and the material use for the crank pulley... choose wisely, aluminium is lightweight but fragile... unless its an aluminium alloy ..
3zz
118
45
for lightweight pulley,make sure its dampened..
if x patah cracnkshaft..
but how to identify the crankply if dampned or x?
question n ans in 1.LOL
ericgtmythos
184
13
Kedah
Bro Bar, Thanks for the good experience sharing:proud:..
---------- Post added at 01:19 PM ---------- 6 hour anti-bump limit - Previous post was at 11:59 AM ----------
my bad:biggrin:
anyways we can share cam pulley experience as well...:idea:
Haha Bro Zeus....:biggrin::biggrin:
Anyway,my CAM pully use TODA old model...come with engine i bought..
See photo attach..:burnout:
---------- Post added at 01:22 PM ---------- 6 hour anti-bump limit - Previous post was at 01:19 PM ----------
Dear All Sifu.....
Finally i decided use back the ori Crank Pully to prevent any risk or side effect to my new rebuilt engine....
Thank u very much for your kind advice & appreciated !!!:top::top::shakehands:
ZenGTMM
Aug 30, 2010
503
Hi there, newbie here too, tumpang thread..
Just want to ask if like say using an undampened crank pulley will cause problem, however I have tried to find dampened crank pulley and the closest I have came across is just Mytheology dampened crank pulley which I have read that its just a play of words and not really dampened as claim. Any ideas which brand carries dampened crank pulley for SP4H?
AFAIK, a dampened crank pulley is really really needed for high performance engine when the torque created on the piston pushing down on the crankshaft causes harmonics and when it reaches resonance state it will cause maximum damage. Will that possibly happen on a NA 1.6 Campro engine?
ericgtmythos
184
13
Kedah
Haha..Bro Bar & xtremeleo... no problem the Teh Tarik or Kopi "O"... Hopefully really have opportunity to meet u all in future... Cheers..:cheers::cheers:
zeus83
981
55
KL-Damansara
eh bro, a bit off topic, forgot to ask u....how is the banjir in Kedah?
ericgtmythos
184
13
Kedah
Bro Zeus, thanks for ur care. Actually my state is Sungai Petani, Banjir only happened at Alor Star, so here are safe....If not my car will be a SAMPAN d:s::s:...... God Bless...:smile::smile:
Here's one for you gaming buffs, the Bugatti Veyron leads the list of the most-raced cars in the game Forza 3. No surprise there as the Veyron blurs the line between engineering and art, blending 1,001hp from its nuclear bomb of an engine with the aerodynamic engineering that could rival a Formula One car and the luxurious interior expected from...
