zc twincam dohc
elvis3000
162
gv me some tips about my EF3 JDM ZC DOHC
1, use sr20 turbo (come 4000rpm)?
2,port n polis head
3,store piston n rod
4,ecu 0bd0 (what is the best ecu to use) stand alond?
5,510 evo injecter
6,255 fuel bump
7,gasket (double)
how psi i can run and safety 1000rpm 6800rpm
stupiddog
200
2
bro is not how much psi u wan.. is how much hp u wan for ur engine...
---------- Post added at 10:02 PM ---------- 6 hour anti-bump limit - Previous post was at 09:54 PM ----------
2,port n polis head
5,510 evo injecter
6,255 fuel bump
7,gasket (double)
turbo u can try using td04l from gsr
port and polish head not necessary... if u got money u can do it..
piston and rod u can use back unless u are going for higher hp then u need to change it..
ecu.. seems u r using obd0 u can rechip ur ecu..
injector 450cc is enough...
fuel pump u can use back ur stock fuel pump not necessary to change..
elvis3000
162
can tell me turbo is t3/t4 ? in ebay. all both on kit using this turbo.
stupiddog
200
2
i think t3/t4 is a bigger turbo compare to td04.. so higher rev to spool it.. stick to td04 unless u aiming for high hp in the future u can use t3/t4... normally i see honda ppl using t3/t4 are fully build engines..
speed2horizon
2,798
334
1,683
T3/T4 is a big turbo to supply u power all the way to 3++hp. However, if u use ur car for street driving, the lag is crazy. It'll roughly kicks in ard 4kRpm. Then u'll feel the pull. Highway, nice. 1/4 miles also nice. But there's alot of other supportive modification to make it feels nice.
JINEIL2EN
Over 10,000 RPM!
15,321
525
Island Of Pearl
team99ers.2.forumer.com
2,port n polis head
5,510 evo injecter
6,255 fuel bump
7,gasket (double)
1, use sr20 turbo (come 4000rpm)?-i reco using IHI VF43 from scooby, less lag.
2,port n polis head-if budget allow, just do it.
3,store piston n rod-stock rod won't last, get b18b 1.
4,ecu 0bd0 (what is the best ecu to use) stand alond?-get a hondata s300, put into ur obdo ecu.
5,510 evo injecter- reco using RC.
6,255 fuel bump-great choice & its a must when aiming for 300 over.
7,gasket (double)-get cometic gasket, watever size & thickness u wan oso can, dun use stock & squeeze 2pcs into 1 head...
just 1 cents..
elvis3000
162
b18b1 pistol n rod to my zc engine? high compressor ?
elvis3000
162
nissan motor 16v turbo.. what compressor about it turbo
---------- Post added at 04:00 PM ---------- 6 hour anti-bump limit - Previous post was at 12:32 PM ----------
b18b1 rod just plus n play?
stupiddog
200
2
b18b rod need to do machining in order to fit in ur block... 16v turbo is from nissan rb20det... currently im using it on my engine now...
---------- Post added at 03:31 PM ---------- 6 hour anti-bump limit - Previous post was at 03:30 PM ----------
b18b rods can take up to 300hp...piston u can change to vitara pistons..
elvis3000
162
where can i get the g16 vitara pistons. can use original vitara pistons or NIPPON n YCP vitara pistons
---------- Post added at 02:25 PM ---------- 6 hour anti-bump limit - Previous post was at 02:20 PM ----------
bro u car run how bar? and h/power.
speed2horizon
2,798
334
1,683
His car is on second stage project in progress..
stupiddog
200
2
dont need to use original vitara piston.. i got my ycp piston for less than 600 but it is bigger bore.. 75.5 mm... so ur block need to bore bigger abit.... running 0.5 bar but h/p dunno... hahaha
elvis3000
162
ycp piston u got sell bro? how about ur car? nice to run with 16V rb20 turbo?
speed2horizon
2,798
334
1,683
This is a ceramic turbo. Extremely light and produce effective at very low cfm. Meaning good spool. But, if u are able to keep urself calm and unaddicted to larger G force, u can use this turbo. If u're planning to boost anything higher than 0.9 bar, the turbine fin will fail due to the pressure n heat at high rotation of the shaft.
A good choice would be TD04L from 4G93T gsr for 1.6L. Good spool n reliable if
maintain well. Good output too...
stupiddog
200
2
as speed2horizon said.. 16v rb20 cant boost over 0.9... ... for my single cam.. the boost will come in at 3k rpm ...just the range i wan it.... as for the ycp piston i can get for u ... but i need to contact my friend and ask about the price... if ur really interested in the ycp piston ,, pm me..
