Thank you. Oooo ok, so its does have a difference but I can hardly noticed em' is it?
---------- Post added at 05:12 PM ---------- 6 hour anti-bump limit - Previous post was at 05:02 PM ----------
Wah, saved by the bell, I just about to install the e-manage blue yesterday but kinda 50/50 due to hesitation. If this case, it is better that i dont even install em'.
But My car I've already put in Hot Bits exhaust system from front to back, Open pod KNN, Arospeed Fuel Pressure Regulator. Is it still not advisable.
Of course there is a difference, its just that sometimes you are not able to realize it. But your engine will be definitely more efficient and also smooth and produce power in areas where it lacked before.
It is always advisable to fit a piggy back ECU or a standalone. Whether the engine is stock or slightly modded. Its where everything starts.
With the mods you are running on your car you are not going to feel 100% power of your exhaust system and air filter as it is is not suited to the stock map on your ECU. So i suggest you do go for the e manage as you will be able to see a noticeable difference, you can utilize the optimum of your mods and your engine as well as being able to have good fuel efficiency.
Just make sure you install a EGO Trimmer so that your ecu wont keep resetting itself. And get a reliable tuner who knows what he is doing, because in today's market a lot of people are claiming to be tuners when they are experimenting and learning.
So go ahead install and have fun! If you have any questions to hesitate to ask.
