problems on my engine vacuums
mrevo
86
I'm driving wira with 4g93t engine. Nowadays my engine RPM is very late to turn down when I rev the engine, seems like the throttle body late to close. the boost meter also late to turn down. anybody knows what happened?
mrevo
86
yup...some time ago. So, is that must be adjusted again?
boyzone
2,669
5,148
If TPS had been adjested some time ago, should not a problem.
Just check and see have any leakage on the vacuum / manifold and vacuum hoses.
mrevo
86
i think throttle body vacuum hose was leak...
I checked the vacuum hoses but no leaking/cracking. Normally, if vacuum hoses leak...the vacum will drop and make the engine RPM unstable.
boyzone
2,669
5,148
If comfirmed not vacuum leakage, just check on ur TPS.
maybe need to recalibrate.
hope can help. Thx.:nurse:
masrun82
From Facebook
Dec 30, 2009
9
ok ....how about ur buterfly throttle....clean it....or cek ur fuel setting or cek motor oil....or cluth
mrevo
86
Thank's to all, the prob is already solved. Actualy, the T joint that jointing the vacuum hoses fro TB, BOV and boost meter was melted and blocked the vacuum towards the boost meter. Now, the acceleration is smooth also can boosting as well.
Honda Civics are generally respected as reliable transportation, and aren't supposed to be prone to things like, say, wheels falling off. But that's the reason Honda is recalling more than 182,000 of them made in 2006-2007 (USA model).
Honda says the trouble comes from a leaky O-ring in the wheel speed sensor. Water could damage the wheel bearing, which could result in one of the four wheels falling off, "possibly...
