nope u can use TD04H or L or HL no worries..diffrent between L or h or HL is their internal part that all..but still in same family of TD04..Hi sifus... I'm planning to BOT my 4G92P SOHC. I'm planning to BOT a low pressure turbo. Which would be around 0.4 bars... I'm in the process of buying items for my project...
But I came across this problem of identifying which turbo to use... May I know what's the difference between TD04H and TD04L...
Is there any problem if I use TD04H??? Can anyone help me...?
Yes... suppose to come together... But, if you chose to use wastegate, u can ignore the actuator.does actuator attached with da turbo?wats da part number?u can c on da compressor housing..
td05h big 16g can make 350hp,ofcourse cant use td04L to make fully modify car coz turbine wheel will going out from the exhaust lol~hello guy i want ask about turbine evo3 big 16g how many HP can sapport ?
and and if modified gsr engine fully modified do i have to change the turbine mine use TD04L
thank you
thanks bro.this turbo this TD04-11B single blade,is very good for low rpm like 2.5k will full boost already,it very response turbo,but untill 5k rpm will drop power band,many diesel car is use this turbo
