Mitsubishi Turbo specifications.
advinlkm
132
hi guy,looking for etena twin turbo spec 6a12tt...can change bigger turbo ? what model of the original?itzit td025?
speed2horizon
2,798
334
1,683
Hi sifus... I'm planning to BOT my 4G92P SOHC. I'm planning to BOT a low pressure turbo. Which would be around 0.4 bars... I'm in the process of buying items for my project...
But I came across this problem of identifying which turbo to use... May I know what's the difference between TD04H and TD04L...
Is there any problem if I use TD04H??? Can anyone help me...?
bebolagalas T
733
29
nope u can use TD04H or L or HL no worries..diffrent between L or h or HL is their internal part that all..but still in same family of TD04..:driver:
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
L = Large (Compressor wheel)
H = High flow
HL = High flow + Large
speed2horizon
2,798
334
1,683
thanks... But I've already got myself a TD04L... I guess not so much of a problem kua...
turbojin76
64
does actuator attached with da turbo?wats da part number?u can c on da compressor housing..
speed2horizon
2,798
334
1,683
Yes... suppose to come together... But, if you chose to use wastegate, u can ignore the actuator.
Part number from the drawing is 12501
contreasjun27
9,000 RPM
9,045
25
subang
guys...got 1 noob question..
TD05 and TD04 using the same adapter ker?
do i need to mod the adapter?
Bump: guys...got 1 noob question..
sooso4e
211
hello guy i want ask about turbine evo3 big 16g how many HP can sapport ?
and and if modified gsr engine fully modified do i have to change the turbine mine use TD04L
thank you
chrissyong
975
14
thank you
td05h big 16g can make 350hp,ofcourse cant use td04L to make fully modify car coz turbine wheel will going out from the exhaust lol~
hellboy69
179
2
guys..
i got this turbo,didnt seem to find it codes from the first page
it is TD04
49177-01700
need help here..
what engine does this turbo belong?
is it good?
my wira 1.8 GSR turbo stolen 30th August 05 @ MidValley Megamall Parking during afternoon about 1.15pm,it was metalic black in color sedan.... No Plate : WHA4739
