Newbie Mivec 1.8
Sapeqlaa
29
1,503
Ipoh
Goodday sifus & ZTH netizens...
I'm a newbie..even not sure where should i introduce myself in ZTH..if i have mistakenly posted my queries at the wrong section...i am terribly sorry...so crossing my fingers here...
Hoping to received enlightenment on how to better off my ride...specs:
Mivec 1.6 head with a 1.8 gsr block
275cc injectors
K&N open port air filter..
sard fuel regulator
walbro fuel pump
PnP head
Adj. Cam Pulley
2.2 piping with straight end
1.5 lsd gearbox
standard mivec ecu...
My questions would be:
a. What are the relevance of placing in a high impedance injectors..say 390cc to a mivec 1.8..does the standard ecu support the output??..if it does...is it safe??..
b. Currently have a small budget around 2k to obtain piggyback...thinking of getting e-manage...some say, go for bling2, meaning safc or apexi neo..still in a dilemma...any suggestions?
c. A friend recommended me to install apexi super ignition timing control (SITC)...barang + labor around RM600..is it worth it?...can i couple together piggybacks and SITC?...or is it redundant?...
pardon me if some of the questions have been already discussed before...still learning to find my way in to this website...TQ...
cheers... :)
ariolz
243
err im not a sifu so dont take my answer seriously :biggrin:
A. maybe if with proper tuning. malaysia boleh!
B. get a piggyback better then those safc or neo. piggyback can do much more then them.
C. sorry no answer from me. ill like to know too! :biggrin:
E-Tech
1,115
256
3,183
Johor
Your can put "chip" in your ecu. Rm300
Your can go get a set of hi cams. RM2000+++
Your can fix e-manage.... then no need sitc... (emanage also can control ignition timing) Rm1200+200 (tuning)..
Your 2K...
Tq
P/s chip will up the rpm cut
will remove speed cut
will add fuel and ignition
I say chip + emanage blue...
Then got more money cams.... becos if got cam but no management then susah lah....
If got e-manage good but cannot solve speed cut or rev cut the proper way...
OK?
BTW... your ecu code or number?
Sapeqlaa
29
1,503
Ipoh
Sifu E-Tech..
Yes sir, i've heard about the re-chipped ecu...btw..my ECU code is 7035 (standard blacktop code i guess)..so i'll not consider the injector and the sitc..
as a conclusion, the best way to spend rm2k and to get whole package:
a. Get the e-manage blue
b. Re-chipped the ecu
btw, its easy to get emanage...do you have a good place for me to get my ecu rechipped?...and also contemplating on the high cam...does 272 degree sounds so ridiculous for daily driving??..TQ..
Sapeqlaa
29
1,503
Ipoh
y dont u get a standalone ECU rather than piggyback?
Sifu Danz,
Earlier i was saving up for standalone...Haltech Platinum Sprint 500 to be exact...barang + install + realtime tuning = RM3800...but was called off due to over budget for my sunroof project hehehe...the roof job set me back around 1500++...tats y im left with RM2k for engine management...
Got no choice with that kind of budget...but still scouting around for 2nd hand Microtech LT8 though...hehe
E-Tech
1,115
256
3,183
Johor
Sifu E-Tech..
A good place? Me also can do it...:biggrin:
272 with good tuning can be driveable also..mivec mah... some cams below mivec rpm
still very drive able...
joe_mirage
1,030
44
1,648
rotationperminute.blogspot.com
Hello Mr Sapeqlaa. I'm not mivec sifu but i think mivec 2nd profile is higher than 272 degree. So i think if u wanna plonk in high cam for mivec, the camshaft spec that available in the market now is only 30+ degree. correct me if im wrong.
Btw Mr E-Tech, ur chip is custom to engine spec? looks delicious.
Sapeqlaa
29
1,503
Ipoh
Sifu E-Tech..
Where u at?...Johor?...r u doing emanage as well??...thinking of doing it one shot..rather than having it separately...
Or do you have any standalone good deals??hehehe...
---------- Post added at 12:51 PM ---------- 6 hour anti-bump limit - Previous post was at 12:47 PM ----------
opps...my bad, 2nd profile intake around 288 degree...fuiih...no wonder in stock form it really goes...hehe..
joe_mirage
1,030
44
1,648
haha. thts why bro. mivec 2nd profile , intake 288 end exhaust 300. very powerful already. if want something hardcore, go for jun type 2. hehe.
bro maybe if u want a good piggy, u can try emanage ultimate. more tuning points than blue. just my 2cents. stand to be corrected.
E-Tech
1,115
256
3,183
Johor
True.. but utimately more expensive....:biggrin:
---------- Post added at 08:34 AM ---------- 6 hour anti-bump limit - Previous post was at 08:30 AM ----------
Yes for certain engine set up BUT not Custom tuning...
e,g mivec chip- for those with 1.8 block and ETC...
Sapeqlaa
29
1,503
Ipoh
Sifoo Joe: That's the thing with ultimate...too expensive..top up a bit, can negotiate with a intermediate standalone already...btw, thanx for replying the post...
Sifoo Etech: Really interested with the ecu rechipped...is there any way for me to set up an appointment with u??
E-Tech
1,115
256
3,183
Johor
Bro
u r in Ipoh?
Trust me? Post to me lor..
Tq
E-Tech
1,115
256
3,183
Johor
Ya lah... then post yourself meh???:biggrin:
Post the car, then I chipped the ecu, and fix the e-manage blue and butt dyno tune it....
How can onot? Okaylah... i degree(set) the cam for you also lah... you got adjustable cam pulley right?... You want 4 throttle not? or just put in b series ctr intake manifold and super90 70mm TB... and let me know your targetted horsepower....
Tq
P/s if serious PM okay..
civic713
68
Terengganu
Bro E-tech....
i still confuse....if using the ctr intake...and super90 70mm how the wiring for TPS. need mod.
artworkz
706
119
JB
tumpang thread.. i m oso driving a mivec+93 block, i feel my car now quite high fuel consumption. 10liter run 70-85km. mind share ur mivec fuel consumption?
E-Tech
1,115
256
3,183
Johor
Bro E-tech....
Super90 does not come with tps...need to transfer ur mitsu tps into it or
get a honda tps and connector but will need some minor wiring job......
Both brands of tps uses 5v signal...
hi bros and siss, i was about to change my spark plug from stock to iridium type, but i just wonder which one is better. denso has its reputation in its performance and durability, especially with its 0.4mm and it U-grooved. but wat i know about volker iridium performing good also. it has 0.5mm and can last up to 160,000km. budget wise, both is about the same. however, for Gen2, wat do u guys think? which one is better? o there is other recommendation? 1 more ques, about denso iridium POWER...
