fast
khoo198
1,948
2,067
N9
driver need the keep fit planning to reduce body weight........:biggrin::biggrin:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
how to make my kancil faster without changing the engine or upgrading it with a turbo
what cc are your engine? they say, no replacement for displacement
I'm no expert but usually ppl will start to say
  1. upgrade intake such as CAI or open pod or
  2. 3 throttle (EFI) or bigger carb like the old saga's carb if you're running carb that is
  3. properly tuned exhaust such as manifold, piping, muffler etc
  4. playing wif cams and adj campulleys?
  5. use bigger and higher compr pistons?
  6. port and polish head
  7. balanced and blueprinted..
  8. tuned it wif piggyback like E-Manage/SAFC if using EFI or retune ur carb like jetting or sumthing
got money and time anything can.... but the cost effective is swapping wif Mira Turbo engines... best power to money ratio...and FC not that bad (u wanna save FC, dun boost much)
...oops, almost forgot... removed unnecessary load from your car... we can skip the driver parts since u sez you are small :rolf:
remove any unnecessary items like spare tire, rear and front passenger seats, door trims, dashboard, use lightweight rims etc...
...I'm not joking here....
HKS-GT2835R
1,193
83
5,148
kelate
engine works better when pulling light loads.
strip down the car to bare essentials, mod is cost-free oso :biggrin:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
bad days comin already...
i found out my Accord SV4 2.0 engine was leaking engile oil~~~
can this be repaired? how much? at where?
if the repair cost is too expensive, then i rather buy a bottle of 4L engine oil and top up when needed...
