Post your kancil top speed here..
mick87
576
112
So far mine 140 km/h on my auto 03 ,havent try harder yet..
kreal
17
i once reached 140km/h with my mom's 660auto 97..downhill a bit i think..
Gt_Cuore
24
1,503
i have a cuore 850cc carby in horrible shape. It got to 120km/h. It needs rings and stuff. Want to drop in a EF-JL but very hard to find in jamaica:bawling:
mick87
576
112
car like floating at 140km/h,if one small stone hit the wheel..!#@!@$&^8....
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
when my kancil used 850cc ED-DE DOHC EFI with auto 3 speeder....it reached near end meter (160kmh i think :hmmmm: ) once but the engine was 'meraung' like hell... :bawling:
after at least 200k km, its retired and replaced wif JB-JL 660 turbo manual from L5 hufcut...
now, hitting 140kmh are very2 easy :love:
never hit higher than that since I don't remove the speed limit... sayang engine maa :driver:
mick87
576
112
wow..so sweet,L5 engine..may i noe the hp of the engine? the only main concern is there are very little safety features of the car..eg. too light,soft body,no abs....but after all it served me well since the car got not much prob for the past 6 years,the only mod is the pulley,makes the car accelerate better than normal and the some anti roll bars
Jun 10, 2009
4
wow talking about top speed? same engine can provide same top speed as long as ur engine r in good condition without modified the gear ratio it self. changing the final drive or ratio may change ur topspeed either increase or decrease.
upgrading ur engine performance doesnt mean u:proud: r upgrade ur top speed too. it just change how fast u can reach ur top speed from standard one.
palen_22
88
5,008
Mine 120km/h EF-JL 660 Turbo. Ring out lots of compression lost , smoke and stuff... :smokin:
msip
59
1,508
when i'm using auto carbie 850cc, my top speed is about 150km/h.. but to reach my top speed realy2 took lonnggggg time.. hahaha..
now i'm using 660cc L2 LSD version, i dont know my top.. but in gear4 can reach approximately 155km/h.. in gear5, i think u do the math.. hehe.. my engine is L2 stock and speed cut is removed..
but my advice is, if u want to drive fast with kancil, better go tune it chassis and upgrade your brake pad first.. for standard kancil, u can use slotted disc brake and better brake pad.. for turbocharged kancil, better use standard turbo disc brake,but upgrade its brake pad to performance one..
just my 1cent..
Gt_Cuore
24
1,503
I want to achieve those speeds so i bought the ED53 engine 850CC EFI. I want to turbo it and need some low compression pistons. Which other engine can i get htose from??:hmmmm:
palen_22
88
5,008
how about sticking to the oem pistons, add on metal gasket instead. retard the ignition.
just my 0.0001 cent :stupid:
220mph
453
28
kl
few days ago.. i was following a boosted kancil in grand saga highway.
try to see what speed that kancil can do..
out of shock.i was following him at 195...
totally speechless.
i was thinking he better not crash in the coming corner..
its scary to even look at him. serious!
mick87
576
112
totally speechless.
walao..tis is scary..tat car must b floating..if crash then ntg will b left
pakram
51
1,508
I got about 160-165km/h when 850cc engine still in my car... then, I replace with L502 single cam.. Now..I dnt know the top speed because my meter is hitting the meter frame after 140km/h.. (dnt have rsm..no budget)...
I did to ipoh from rawang..its take about 40 minutes (angry girl is waiting for me in ipoh :girlshit:).. but, "kesian engineku" ...I lost 1 stad n 2 nuts for tighten between turbo n exhaust pipe..(it happen the next day in shah alam..:stickyman:).. Im using this engine about 7 years..that the only time I did..never before or after..
If u want better performance for ur kancil...with easy way... just change to a lighten rims... believe me, is worth it..:vroam:
PeeJay
10
Talk about max. Kancil speed? intresting. My one is standard 850 EX manual year 2002, Can go up to 145kmh. but last few week, gear box "konG" and replace it with second hand. Damn! the workshop not inform me they install 660 gearbox, i think... :mad:
Now full throttle .. 117kmh only, at 5800 RPM. Diff, gear ratio.
Think about change to L2S or L5....:hmmmm:
My friends car been into accident.A car hit his car at the front wheel.Sent to the workshop to repair.After bring back his car from the workshop,he notice something abnormal at the wheel side.Whenever the car into any bumper or a bumpy road,there is a sound like the tyre hit the top part of it.So he asked me to checkout.I found that the wheel alignment is not in correct position like the picture below.The top part(green arrow) and right side(red arrow) distance is very less compared to the...
