IHI RHC7 1jz help me please!
pyke
5
well sorry for making this on a import fourm but i am a 2.2 chev cobalt.
i recently bought a IHI RHC7 1jz and plan to put it on my car.
well i been told that this will blow my motor because the exhaust side is to big.
well my motor is built for boost and its sleved. all forged internals and the head is being build soon.
just wondering if anyone can help me under stand this turbo, i went from a GT2871R to this HUGE monster!
thanks
rajie
1,318
15
pantai hillpark
i got a IHI RHC6 in the hse its the same as TD06 20g max hp around 400hp and max boost at atound 1.6 -1..8bar....do u have any pic of ur turbo ???????/
pyke
5
Do you know anything about oil to the turbo do i need to restrict it any or is it okay to be full open?
heres some pics
khoyos
2,633
156
5,163
Shah Alam
i think its going to be too big for ur cobalt. u can try to change the turbine housing to a smaller size. maybe T3 a/r 0.82 but i'm not sure if you can use garrett turbine housing on IHI turbo.
jinkl
4,623
376
3,183
thanks
tell me whts the reading at the exhaust housing, there should be some numbers over there
if its too big, it wont blow ur engine, it will just be laggy n not make power, u need something thats sweet n nice. the most important thing for a big turbo like this is TUNE :)
pyke
5
looks like it says Q35E and on the other said it says A5
the motor is being built sleeves, rods, pistons, the whole 9 yeards
proPIPING
1,077
5
i have one of this turbo...can find ar 0.78 back housing from the lorry chopshop around segambut...if the diameter of lorry is small just lathe it to fit...anyway what is your ori ar?it look like 1.++ ar
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
Q35 is very huge mate.
where you located please ?
we may have a smaller used turbine housing sitting on the shelf, no promises.
As for oil, it's ok to go full flow.
Could you snap a picture of the IHI name plate, it'll tell us more about the turbo.
pyke
5
I have NO clue what your talking about sorry about that. can you help me understand some more.
Bump:
yup i will do that right now here you go.
sorry my camera wouldnt take a clear shot but here is the stuff it says:
spec:VQ41FCW37S
Serial No.: RHC7 7114303
Parts No.: blank
IHI JAPAN
and above the tag it say TAC-37
and i am located in Nova Scotia, Canada
proPIPING
1,077
5
Bump:
spec:VQ41FCW37S
Parts No.: blank
IHI JAPAN
opps sorry mate..i thought you from kl,that's why you don't know segambut..
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
apparently VQ41 = RHF4 = used on Daihatsu Diesel...hmm...but your name plate details are all wrong.
Prob the person who made this turbo had the "intention" to midlead others..so if you tried ordering for the same turbo...you'd get a wrong spec !
Anyway if u'd like you could look up local performance shop to help you downsize the Q35 turbine housing...way too large now to use.
pyke
5
so my best bet is to stick with the GT2871R i have then
SDF
missing her so much
Nov 19, 2003
2,354
275
5,183
KL, Malaysia
pyke mate..why not talk to the local turbo re-builders..they might be able to help you out with something.
GT2871 is good ...probably for now and if you wanna bump up more power..try a GT35R..it should be good to give you 500-600 horsies. :driver:
anyone know what is the size of the stock front disc rotor for wira? is it same size with putra rear disc?
