4G91 Gearbox for MIVEC 1.6
starscream
147
Anyone tried this combination before? can the 4G91 gear box sustain or go to high rev like the MIVEC? please advice all the sifu!
kroolada
3,260
2
i not sure the final drive ratio but below than standard proton 4G9X 4.32 final drive. suitable for topspeed run , not for drag if used at na engine below 200 hp.
for ur spec mivec 1.6 , standard mivec final drive ratio 4.59 is the best with on the road body.
darkwizard
31
4
1,508
Kaching...
Not adviceable as it will be very sluggish in acceleration as the powerband when gear changing all will be out.
Its feels like starting the car on 2nd gear to move the car from stand still, and also when gear change it feels like shifting from 2nd gear direct to 4th gear....
skylee834
330
4
my car 4G91,change out ratio 4.5...good for drag but top will loose...using super light flyweel.....can go till 8.5 K-9k RPM still not problem...
kroolada
3,260
2
how about 1.8 mivec,what the best gear box combination.?
:smokin:
need to give specific data bro , what type of driving....drag, track, or street used.
also spec of the car like body weight , rim n tyre size , engine hp n tork , cam spec , etc.:driver:
bhd 884
74
klia 3
used satria
145++hp
everything standard inside
some time used hard on karak highway
just need spec or some one can help for ratio that gear.:bawling:
boyzone
2,669
5,148
If u r a highway man, u need to use 4G91 gearbox ( FD=4.021 ) to have a fuel economy and more relax on ur engine RPM.
For those hard rock, mivec need an original gearbox to match.
bhd 884
74
klia 3
thanks man,hm...anybody want to sell mivec gear box?hehehe.......
anyway i have anther question,
how to custom made gear ratio 2,3,4?
sape2 penah buat atau kat mane nak buat?:slug::nurse:
hi, i owned a wira 1.3 injections year of makin 2003. the car was using semi synthetic oil since the start n never missed an oil changing schedule. Recently, the car have a few problems. Early morning when i start the engine, the idling were not stable even after it has been warm up. And the dashboard meter showed an "engine check" sign even when i start to drive the car. After a few hrs of driving and park it with engine still running, there is a scent of petrol humes from the exhaust...
