Mitsubishi GTO front disc
tctho
8,000 RPM
8,006
Hi friend, can you give me that brake disc spec L*W*H. and best prices...:listen:
I dun hv the dimension right now. Once i get it will pm u. What car u want to fit this disc?
kariayam
191
48
i got 16 inch rim, offset 40., will the caliper fit into my wheels without any problem?
I have a 1600cc 20v and i would like to know of any other modification that can be done to it. As it stands it already has on extractors it has a slivertop half and a blacktop bottom half with blacktop throttle bodies a 10lb flywheel it also has a switch inside that i can switch to sorta like advance the value timing i not sure what pistons i am using but i have a standard 20v clutch but i just tell myself and it can do better because right now in my country the TOYOTA RUNX 1800cc 20v is...
